May 18 2005, 09:02 PM
i did a search but could come up with anything.
i do remember someone had a little magick trick to silence a squieky top.
i wrapped the little nipple with shrink-tubing, but most of the noise comes from the big rubber spacer that rubs against the backpart of the lock.
HELP!
it's driving me nuts ...
Andy
scotty914
May 18 2005, 09:10 PM
take the roof off
or a good coating of armor all on the seal
jim_hoyland
May 18 2005, 09:16 PM
Could the tightening of the latches be a cure ?
iamchappy
May 18 2005, 09:17 PM
I think someone used felt?
jim_hoyland
May 18 2005, 09:29 PM
Dr 914 has a section of Tech Tips 700 dedicated to the Roof and some possible solutions to squeaking.
jimtab
May 18 2005, 09:31 PM
Andy, just turn the radio up, up , up.....
r_towle
May 18 2005, 10:00 PM
I think the cure is a new seal on the underside of the roof in the rear...
The one that I have seen is either here or PP tech articles.
It was some normal garage weatherstripping (I honestly cannot remember)
But,it creates a bigger profile, lasts for another 20 years and was pretty easy to do...
Take a look at PP , I think its there.
Then just re-adjust the latches after..it should stop the roof from rubbing on the targa bar..
rich
r_towle
May 18 2005, 10:03 PM
a good cheap test would be to get a few wood shim shingles...drive them in by hand from inside the cockpit and see if raising the roof a little bit solve the squeak.
If not..look at the doors or windshield...but mine was right behind my head...
Rich
May 18 2005, 10:06 PM
QUOTE (r_towle @ May 18 2005, 09:00 PM) |
Then just re-adjust the latches after..it should stop the roof from rubbing on the targa bar.. |
nope, it's not the roof rubbing, it's the rubber spacers that sit in the recess on the lock.
they need to sit in there, if you move the top higher (by adding more seal), the top will be able to slide backwards, which is not good, espacially on the freeway at higher speeds.
the rubber stops need to slide into the recess, unfortunately, the rubber on the metal "squeaks" like mad ...
i have adjusted the lock as far down as it goes, i got it to clamp down pretty tight, but it's still making lots-o-noise ...
i'll know later on my way home if the dry lube worked ...
Andy
McMark
May 18 2005, 10:19 PM
Take the "shine" off the rubber with some sandpaper. That'd be my first attempt. Stick-On felt?
airsix
Andy,
I'm a little bummed to hear about your roof-squeak trouble. I always thought that once I cage my car it would not squeak any more. Dang it.
-Ben M.
dmenche914
May 18 2005, 10:59 PM
The top should be tightened as much as possible, but that alone may not help. Try adding some felt on contact areas on the rear (the original rubber has a strip of felt on it, and might be missing or worn) Add some felt near the rear latch where it touches the top. An alternative, is some silicone grease, but that is a bit messy.
These squeaks can be very very disturbing.
The main thing is to prevent the rubber parts from rubbing on the metal/plastic parts.
SLITS
May 18 2005, 11:21 PM
30 year old rubber is hard as rock....it's gonna squeak. While your driving, instead of choking your chicken, use your free hand to push up on the top.
markb
May 19 2005, 12:14 AM
Someone once told me to put a bit of baby powder on them to make them stop squeeking.
wheelo
May 19 2005, 01:09 AM
Andy-
I remember "Aquarium" Rubber tubing being used on the post, that the
latch grabs-on-to ! This helps tighten/eliminate squeak. Mine only squeaks during certain types of weather...
so I can live with that... but being snug is key.
- M
May 19 2005, 02:30 AM
"dry lube" worked!
now i have to apply that to the glove-box door hinges!
Andy
Porsche Rescue
May 19 2005, 09:11 AM
Lube the little plastic blocks and the notch they sit in on the latch. The squeek is not from the seal.
I once drove 2400 miles home with a car I bought in Chicago. The squeaky top damn near drove me bonkers. Got home, talked to PO and he said "oh yeah, I usually put a piece of paper, even a dollar bill, under the plastic block and it goes away".
Toast
May 19 2005, 09:18 AM
New Seal baby...........new expensive seal.
Joe Bob
May 19 2005, 09:23 AM
When I had a top that would come off....mine is bolted down...
I used the dry lube AND added felt under the roof where it contacted the targa bar. Tightened it, got rid of wind noise and squeeks. The seals were new but the latches seemed to have stretched.
balljoint
May 19 2005, 09:48 AM
QUOTE (SirAndy @ May 18 2005, 11:02 PM) |
i wrapped the little nipple with shrink-tubing, but most of the noise comes from the big rubber |
Was gonna say powdered graphite (dry lube), but it looks like you got it figured out, so I will just add a quote. A little out of context but it made me laugh.
Jenny
May 19 2005, 10:52 AM
QUOTE (Sammy @ May 19 2005, 08:33 AM) |
(Jenn, they aren't expensive ) |
It wasn't I that said it was expensive. On the contrary, I got a great deal from you I believe the Toasty One cried expensive.
Andy, if the dry lube stuff works, save some for me. Or point me in the right direction. My top squeaks like crazy! mostly I hear it from the rear passenger targa area.
Before anyone blames 30 year old rubber, I have newer seals on my car (2-3 years old)
Jen
Porsche Rescue
May 19 2005, 11:00 AM
Once more, I don't think it is the seals. Sand/lube the small plastic blocks at the rear of the top. The top rides on those and that is where the squeak usually is.
When I went to the garage to take this pic I found that PO had put some tape on the bottom of the hard plastic. I took it off. When I put the top back on I bet it will squeak.
Jenny
May 19 2005, 11:03 AM
Thanks! Will try it as soon as I get my grubby little hands on the car.
Jen
rhodyguy
May 19 2005, 11:08 AM
a piece of adhesive backed felt placed in the recess in the targa bar works well. it will rub away eventually, just stick a new piece in when it does.
k
Brad Roberts
May 19 2005, 11:13 AM
Ben,
We dont run front latches on the tops after the car is caged. (at least with Andy's cage design)
See... I was sitting within 4 feet of you and you asked the board before you asked me..LOL I'm not sure how long the dry lube will last, but at least it got you home. I wanted to tell you "Glycerin" but I couldnt recall it last night.
B
Jenny
May 19 2005, 11:33 AM
QUOTE |
Sammy saw cleavage in an avatar an automatically associated it with Jen. |
It happens to the best of us. I'm quite a bit darker than Toast, which is ironic, if you think about her user name. Toast is to porcelain doll as I am to hula doll.
Jen
jim_hoyland
May 19 2005, 09:20 PM
Could someone post a picture of the squeaky part ? I'm not clear where the squeak is from---I have it too
May 19 2005, 09:31 PM
QUOTE (jim_hoyland @ May 19 2005, 08:20 PM) |
Could someone post a picture of the squeaky part ? I'm not clear where the squeak is from---I have it too |
se rubber thing is rubbing against the recess area in the lock, causing the squeek ...
Andy
PS: "dry lube" on both parts and it's quiet now. which means now i can hear all the other little things making noise!
jim_hoyland
May 21 2005, 07:14 AM
That worked !! Thanks
Now I can hear the sway ar bushing ? Should that bushing be lubed from the inside or can it be done from outside ? I only hear it during dry weather.
Anything special to know ? I installed the Wertmeister about a year ago.
dgw
May 26 2014, 03:55 PM
What a pleasure to find this old thread when searching for squeaky tops. I didn't even know that piece was rubber, plus some PO had painted mine black in some ancient past which I suspect helped them get harder and dryer. My rear sway bar bushings used to squeak so bad I couldn't hear the top but new Elephant rubber fixed that. I hope that one of the suggestions in this thread fixes my top squeak.
partwerks
May 26 2014, 04:07 PM
This is the first 914 I've owned that the top does not squeak.
I wonder if putting a piece of waxed paper under the block would help?
motorvated
May 26 2014, 04:48 PM
QUOTE(! @ May 19 2005, 09:23 AM)
When I had a top that would come off....mine is bolted down... <!-- emo&:blink: -->
<!-- endemo -->
Install one of those unspeakable Chalon kits, and live with the pain.
May 26 2014, 04:53 PM
QUOTE(dgw @ May 26 2014, 02:55 PM)
Yes, both of the main ideas in this thread work.
The big rubber block can be sanded and lubed and the small hinges can be wrapped with some rubber tubing.
I just did both on my car before leaving for the WCR in Tahoe and the whole weekend was free of top squeaking.
dgw
May 26 2014, 05:15 PM
Felt pads worked great, no more squeak.
ndfrigi
May 26 2014, 05:32 PM
Replaced my rear targa seal that I got from my parts car and there you go no more squeaky sound.
Krieger
May 26 2014, 05:51 PM
I'm glad this thread popped up. I'm getting parts together to put my top back on my car and I had an assortment of rubber blocks from two different cars. The taller one fits inside the the latch assembly, while the shorter one will squish down between the shoulders in the latch assembly. Almost 4mm diff between them in height. I think the shorter ones came of my 75, but I'm not sure. Are there different blocks, or just mangled ones?
May 26 2014, 05:53 PM
QUOTE(Krieger @ May 26 2014, 04:51 PM)
Early and late. Do a search here, Paul made a great thread outlining all the differences ...
Krieger
May 26 2014, 06:00 PM
I tried a search, but what do you call the dang things?
May 26 2014, 06:32 PM
QUOTE(Krieger @ May 26 2014, 05:00 PM)
Targa Tops ...
BIGKAT_83
May 26 2014, 06:40 PM
ripper911
May 26 2014, 07:02 PM
Silent-blocks
