Full Version: HOW to Replace intake Gaskets?
rfinegan
I order up some replacement intake gaskets for my retro fit of the D-Jet back onto my 2.0l from Webers. My question is about the plastic intake gaskets and the addition of sealant or paper gaskets to go with them. The replacements look to be plastic phenolic with out paper on each side like i have seen and used in the past. Do I need to add the paper gaskets with the new phenolics? I have used aviation sealant in the past and was successfully sealing the IDF manifolds. Any advise would be appreciated
Best Regards
-Robert
Front yard mechanic
Quick question where did you order the plastic spacers? One of mine is cracked and I made fiber gaskets to try and hold it together seams to work but for how long? stromberg.gif
maf914
Porsche 914 intake gaskets can be found on Ebay and Amazon among other places, such as the VW or Porsche dealer parts department:
https://www.ebay.com/sch/i.html?_from=R40&a...et&_sacat=0
https://www.amazon.com/s/ref=nb_sb_noss?url...4+intake+gasket
malcolm2
In the eBay photo you can kinda see that the edge is white or at least lighter. I just replaced mine and I thought the same thing about the paper. Can't remember where I got them. Don't think they were $20+ tho. get the part # from AA and search. It might have been AA where mine came from.
I also used sealant. Red RTV stuff. I remember partially tightening the nuts and letting the sealant cure abit, then torqueing.
I was fighting some vacuum leaks on my L-Jet. All is well now.
brownaar
Recently replaced mine. No sealant. Made sure contact surfaces were clean and torqued to factory value.( Something like 12 ft/lb. Not much, I do remember.) No issues. Car running great.
QUOTE(brownaar @ Aug 28 2017, 10:54 AM) *
Exactly what I did when I replaced them on my 1.7
Spoke
I made my own paper gaskets from gasket material from my FLAPS.
Cut the holes for the bolts and sandwiched the paper between the 2 spacers and bolted together. Used a razor knife to cut to shape. Took about 15 minutes to make 4 gaskets.
Kansas 914
QUOTE(Spoke @ Aug 28 2017, 11:26 AM) *
Very clever!
Kansas 914
I remember McMark saying the few sets he ordered from a vendor came without the paper on the gaskets.
Many years ago they used to come with the paper - things might be changing depending on the vendor.
Kansas 914
Duplicate
era vulgaris
QUOTE(Kansas 914 @ Aug 28 2017, 03:21 PM) *
When I replaced the gaskets on my old 1.7 back in 2013, they came with paper. When I replaced them on my 2270 a year ago, they did not. Both times I bought them from Pelican. I attempted to use the non-paper-having ones anyway, and the result was a vacuum leak. You will have to add a paper gasket to each side of the phenolic. Depending on how long your intake studs are, you might be able to use the cardboard/paper ones that CB Performance sells, which I was able to do just barely. Or you can cut out your own paper ones, as someone else mentioned.
rfinegan
Here are the "OEM" style I got from Amazon without the paper...
brownaar
QUOTE(rfinegan @ Aug 28 2017, 01:11 PM) *
Looking at that photo, I suspect mine were the ones with the paper. Mine looked different. They had a sandwiched appearance.
