hi everyone
i'm removing a certain.... uhmmm ..... non-critical system in my 75 2.0 today. i think i'll go with the ball bearing/cap method of sealing the air injector jets. quick question:
it would seem easier to remove a single air injector jet just to go to the hardware store and find appropriatte fittings. but if i do this, will i have trouble getting a good "seal" when i replace it? should i use a bit of locktite?
or should i leave the air injectors in and try to find the appropriatte fittings using the (removed) air distributor pipe -- so as not to break the good seal that the air injector jets currently have?
any advice greatly appreciatted...
n
