QUOTE(Guberif @ Oct 27 2017, 03:04 PM)
Hey Darling Dave, I totally agree with you I love the 195/50ZR/15 (made by Yokohama - nla for the A-008 type)which I need to replace, can't even find any ZR rated tires anymore.
I've talked to you a couple of times on the phone years & years ago and you've always had Rock Solid advice.
So, here's my question.
I deffinately want to stay with the low pro's no debating that one - your dead right world of difference! But I would like to have more accurate speedo & I wouldnt mind having lower rpm's.
Where the 'Rub' is (forgive the pun) that my tires I have on my chrome rims are 185/65/15. the drivers rear clearance is super tight, can't even get my pinkie in between tire and well. do you know if these chrome rims are totally offset? or are they the same as the Fuch's? (I'll upload pic of the chrome ones)
I will be putting the new tires on my 2.0 L. OEM Fuch's .....so, If I were to go a little bigger with still a 50% would that work? Could you suggest any sizes to check out?
Sorry to ask this, there is no tire shop nearby so I will be having to order over the internet, so I cant just go down to a shop or anything of the sort, that and like I said - great advice before - thanks.
Bonnie
Click to view attachmentBonnie, some 914s came out of the factory with non-symmetrical rear suspension too. The rear track is wider than the front to begin with, so fitting wider wheels is sort of iffy, especially if the offset/backspacing of the wheels isn't correct for the car.
I installed a nice set of 5.5" EMPI 8-spoke freshly powder-coated wheels with Falken 195/65-15 tires on the '71, but the left rear rubbed the fender lip
... The backspacing on those wheels was for VW Bugs/Ghias/Squrebacks, etc. - so I sold them. I stated this issue in my for sale ad, and they fit just fine on the gentleman's car who purchased them.
I doubt you'll have any issues with the (real) factory 4-lug Fuchs wheels though, they have the correct backspacing. Typically, 195/65's on those will present no issues, and a lot of folks do run with 205/60s with no issues either.
In any event, you can install your 'un-tired' wheels on the rear and measure the distance to the fender lip about 2~3" above the outer rim of the wheels (where the tire will be wider than the wheel itself) to see how much clearance you'll have. Caution, though, some manufacturer's tires are a tad wider, even if listed as the same size.
