Full Version: Wide-band preliminary results, EFI guys must read!
Mark Henry
10.5 AFR!! ohmy.gif That’s what I was running!
I was tuning with a Haltech AF-30 narrow band and they are “supposed” to be pretty good. Since I was running so rich before, now my gas mileage should go up and the throttle seems way crisper. I’ll post my fuel values later (before and after) once I’ve fine-tuned them a bit better.
Wide band users! If you’re running an exhaust extension tube, your lambda is not getting hot enough for an accurate reading! Even if it is a heated unit…mine is.
The WMS wideband has an LED that lights up when it hot enough…It took almost 10 min. at the “Y” in my Ansa exhaust (with SSI’s) before I had a green “hot enough” LED. A header would most likely heat up way faster.
lapuwali
Did you tune your car via the Halmeter to be on the rich side, or was that after tuning to 14.7:1?
william harris
Is it just me? I have no idea what any of this means? confused24.gif Wide band - is that like my cable with Comcast? lol2.gif English translation - or better yet - the "For Dummies" version for the rest of us. happy11.gif
Mark Henry
Hmmm.....
Seems like there's a problem with my wideband...I should have a green LED in 15 seconds...It's not heating up like it should. headbang.gif
Talked to Ross at SDS and they're going to Fed-Ex me another meter ASAP.
Mueller
QUOTE (william harris @ May 20 2005, 02:05 PM)
in very simple terms:
the narrow band is like a regular light switch, on/off (rich or lean)
the wide band is more like a rheostat potentiometer light switch, many variables (it's tell you how rich or how lean you are)
mightyohm
Mark - The wideband sensor should be able to heat up even with the car off, mine only takes about 30 seconds.
If it's not heating up your supply voltage may be too low at the controller, or the controller is not trying hard enought to heat the sensor (bad design).
The sensor will not work properly unless the lambda cell is HOTTER than the exhaust gas it is measuring. Totally different than narrowband.
lapuwali
QUOTE (william harris @ May 20 2005, 01:05 PM)
See my blog. I just put a definition there that seemed to help one other person with the same question on another thread.
Mueller
QUOTE (lapuwali @ May 20 2005, 02:57 PM)
See my blog.
Mark Henry
QUOTE (jkeyzer @ May 20 2005, 05:40 PM)
SDS has over a thousand WMS units in service already and I'm only the second return. They think the issue is in the harness.
For the simple install there's only two wires (power and ground) so there's nothing to screw up.
Anyways, I should have a new one by tuesday and they're paying for the return shipping.
crash914
10.5 to 1 is way way too rich....of course that is what my MS is reading....
I know that my WB02 gets hot very quickly. I drilled and installed a bung just after both pipes came together. Bursch exhaust.
Modern FI is the bomb...no matter which you are running..
airsix
Mark/Herb,
This is funny. I tuned with narrow-band to get things roughted in before getting my LM-1 wideband. Guess what. My narrow-band tuned AFR was about 10.5. That lambda curve sure is steep. Wideband rocks. They'd sell more of them if instead of sighting the technical aspects they just said "Buy this. It will fix your AFR, but more importantly it will save your marriage, your relationship with your kids, keep you from losing your job, and help you avoid being institutionalized."
-Ben M.
crash914
My wife hates it when I am tuning in the garage....I am tuning for a 2.35v crossover point...
My car is rich rich rich.....it really stinks at 10.5. But Hey! it doesn't ping!!
Mark Henry
My duty cycles are so low with the 2.0 injectors I'm going to try some smaller injectors....I think my buddy has some 1.7 injectors idea.gif
What other injectors fit a stock injector holder?
My wideband is now hit and miss...same issue this AM but now it's working fine.
Bet it makes me look like a duffus when they test it..."Ummm.... dars nutin' wrong with it"
airsix
QUOTE (Mark Henry @ May 21 2005, 02:47 PM)
Mark,
Try some 1.7 injectors. If 1.7 injectors are still to big you could try the injectors I was using - 1.8 Turbo Subaru. They are hose-barb and a direct drop-in swap. They flow less than the 1.7 injectors so with your displacement (2.2?) they might be too small. Anyway, those are the two options that are probably the easiest/cheapest.
-Ben M.
Mark Henry
Nope...this engine is my stock orginal 1.8 with 75K on it. sold the 2.0
Still gathering parts on my 2.6 T4....still need TB's and a header...only $ in my way sad.gif
airsix
QUOTE (Mark Henry @ May 21 2005, 05:33 PM)
Mark,
If you try the 1.7's and they are still too big let me know. I'll send you my Scooby injectors. They are still in the car and I can drive it - I just can't go above 5,000rpm on boost. Without boost they're fine all the way past redline. I only payed $5 each for them.
-Ben M.
Mark Henry
I'll let You know once I've tried them...Maybe I should try my 1.8 L-jet injectors first.
