retrotech
May 20 2005, 07:33 PM
Is it an attachment on the edge fo the spoiler? Not the spoiler itself.
What is its function, or aide to the spoiler? Any pictures?
Thanks
TimT
May 20 2005, 07:46 PM
A wicker.. is a slang term for a "gurney flap" which is the name of an aero device that Dan Gurney invented
basically its a piece of sheet metal, or aluminum angle that has a vertical leg that at the trailing edge of a wing
TimT
May 20 2005, 07:48 PM
QUOTE |
What is its function, or aide to the spoiler? Any pictures? |
the wicker effectively lengthens the spoiler.. it extends the point where the air flowing over the spoiler reconnnects..
Mueller
QUOTE (retrotech @ May 20 2005, 06:33 PM) |
Is it an attachment on the edge fo the spoiler? Not the spoiler itself. What is its function, or aide to the spoiler? Any pictures?
Thanks |
I believe it supposed to increase the speed of the air going over/under/thru the wing....depends on how you mount it....
sound correct Tim???
TimT
May 20 2005, 08:58 PM
heheh some wicker data
swood
May 20 2005, 09:39 PM
Can't quite read it...can you blow it up a bit?
retrotech
May 20 2005, 09:41 PM
Please try to repost info.
I would like to see pictures of variations. Anyone using one, on a 914 application?
maf914
May 21 2005, 07:29 AM
QUOTE (retrotech @ May 20 2005, 07:41 PM) |
I would like to see pictures of variations. Anyone using one, on a 914 application? |
They are usually used on true wings. Often there is a slot built into upper surface at the rear of the wing. This goes across the width and the wicker or flap slides into the slot. This wicker acts as a spoiler across the upper surface of the wing. It increases downforce, but also drag. Changing the size of the wicker allows the aero performance to be tuned. Sometimes during pit stops the crew will remove a wicker when handling requires it.
Mrs. K
May 21 2005, 08:58 AM
Here is a picture of a spoiler and wicker bill strip on a CHAMP car from the Long Beach grand prix.
slivel
May 21 2005, 12:12 PM
I put one one my spoiler. Not sure if it works but I won my class at Las Vegas. Sorry that I don't have a better picture. The car is not at home right now.
TimT
May 21 2005, 12:14 PM
I resized the scan I posted, didnt realize it was so hugantic
