Joe Bob
May 22 2005, 11:59 AM
I have eliminated a lot of extra wiring and relays and such....how would one best hook up the brake lights to the mastercylinder switch?
Up in the garage on WIFI and under the car.....cold beer is close.....ESPN Sport Center is on....
SLITS
May 22 2005, 12:08 PM
Wouldn't hook to MC stock setup, no pressure accuated switch to hook to.
Wire from hot ign to switch on brake pedal...wire from switch to lights (assuming lights are grounded).
Joe Bob
May 22 2005, 12:11 PM
Yeah that's what I meant...should I fuse it?
messix
May 22 2005, 12:13 PM
wadda ya new
yes fuse it
SLITS
Yeh, if it ever frays and grounds ya get a lotta foul smelling smoke.....kinda like beer and hard boiled eggs.
I suppose it would be possible to mount a pressure switch in a "T" off one of the circuits, but that seems more trouble than it's worth.
Joe Bob
May 22 2005, 12:16 PM
Crud....I meant what amp fuse....
beer, mowing the lawn, heat, setting up the kiddies pool and then working on cars beats ya up.....
messix
May 22 2005, 12:21 PM
if'n just the brake lights a 5er will do.
if you have it ganged with other things on a buss. add up the current + 20% to get your fuse value
SLITS
May 22 2005, 12:24 PM
Inline.....$1.98? at local flaps...5 - 10 amp max.
What happened to the boiled eggs?
Joe Bob
May 22 2005, 12:25 PM
QUOTE (SLITS @ May 22 2005, 10:24 AM) |
What happened to the boiled eggs? |
I fahted, lit a match and turned the channel....
Aaron Cox
May 22 2005, 12:43 PM
back to work son.
get frank done?
Joe Bob
May 22 2005, 01:13 PM
After manfred is done...I am fabricating a dash to use 911/VDO gauges...that's taking time.
Looks like the microswitch is dead....I get 12v to one side with the ignition on....push on the brake pedal, nothing on the other side...gonna pull it and see if it can be fixed....
Joe Bob
May 22 2005, 01:14 PM
It's a real bitch getting in there with the cage.
Joe Bob
May 22 2005, 01:15 PM
Don't say...I will...and my fat ass...
Joe Bob
May 22 2005, 01:36 PM
Fixed it.....crap in the contacts....
