OK, as I'm getting ready to install the Tangerine Racing rear pick up kit, I figured I'd breakout the fancy measuring device I just got and give the chassis the once over.
Right off the bat, I don't get what I expect. Pics call it out, too but:
- I'm 1.1 cm "long" on both front cross member-to-rear console measurements
The good news is they are dead equal.
- I'm 1.35 cm "wide" on the outer console front hole c-c measurement
All other measurements are dead on the printed specs.
It's a '75 chassis. It did get a minor hit in the drivers rear corner but shows no signs of damage that would have contributed to this. Again, triangulation shows it's dead equal side to side.
What strikes me as odd is:
With the inner console mounting points at spec (to one another) but the outer mounting points over 1/4" wide on each side, wouldn't I have "more than usual" space when it came to fitting the trailing arms? I don't...
In Jeff Hail's comments in this thread (http://www.914world.com/bbs2/index.php?showtopic=189224), he calls out "I have seen a half dozen 74-75 tubs that the wheelbase is off by half an inch or more from one side compared to the other."
Not that I have a wheelbase issue, but are the later cars this far off spec? I guess if it's + or - 3mm and my chassis is at the far end of the scale, it's not a big deal.
Am I over thinking all this or missing something silly? Your perspective appreciated.
Chris
