TimT
May 23 2005, 04:37 PM
Well I can build killer engines, weld aluminum, bend tubing for roll cages, grill some mean ribs, and even hang the bodywork on my car so the panels all line up nicely and the car looks "gud"
Im having to blend some areas where I removed the rain gutters and where I blend glass or cf to the steel base..
What do you do about the pinholes in the filler? I guess Im mixing air into the filler, so Ill mix more carefully from now on, but what about he pinholes I find when sandin?
Do these get filler with primer/surfacer?
or do I fill these with a light coat of filler?
inquiring minds want to know
TravisNeff
May 23 2005, 04:40 PM
I believe spot glazing putty is just the stuff for filling pinholes as you describe.
Porsche Rescue
May 23 2005, 04:41 PM
Get a tube of body putty, think they call it glazing putty. Follow directions on the tube. Primer might fill but don't take the chance.
Travis is quick, also must be right 'cause he agrees with me!
TimT
May 23 2005, 04:45 PM
A paint guy told me under no circumstances use the stuff in a tube..but said with the new filler pinholes are basically a thing of the past
something about shrinkage
Im just an occasional aquantaince with this paint guy, and feel like I have used up my advice quota from him... so here I am
jasons
May 23 2005, 05:01 PM
QUOTE (TimT @ May 23 2005, 02:45 PM) |
Im just an occasional aquantaince with this paint guy, and feel like I have used up my advice quota from him... so here I am |
There are 2 kinds. One that is a 2 stage epoxy hardener style and one that just sets up on its own. I know most guys say not to use the old style stuff that is not 2 parts. I have used both and I find the old stuff easier to work with. It was alot thinner and filled the imperfections better. I think if you don't try to fill big holes with it, you will be fine. Also, when you shoot high build primer, it will fill alot of those pin holes.
If you use the good filler, like the Evercoat Rage, pin holes are minimized.
All of that said, I aint no expert. Thats just my experience.
Kargeek
May 23 2005, 05:02 PM
You can buy catalyzed skim filler- it's like bondo but thinner- use it like putty to fill imperfections and pin holes. No shrinkage. Dave H
sixnotfour
May 23 2005, 05:06 PM
QUOTE |
If you use the good filler, like the Evercoat Rage, pin holes are minimized. |
The bobyshop, I snoop around in uses this , no problems.
Tim, They did rdane's no gutter 911 on pelican,I am sure you've seen it.
Jeroen
May 23 2005, 05:27 PM
never had that problem...
are you sure the pinholes are in the filler and not in the f/g or cf?
if you sand through the gelcoat, you'll end up with lots of pinholes
if that aint it, all I can say is that you need to mix up the filler and hardner real gud
TimT
May 23 2005, 06:05 PM
No the pinholes are on the steel side of things Im trying to blend.. On the fiberglass and carbon fiber Im just knocking down the high spots with a long board and calling it gud..
oh BTW i have another pretty good shot of our 935 Ill email you
scotty b
May 23 2005, 06:16 PM
Under NO circumstances should you ever use the one part "glazing putty" that stuff if pure CRAP. As mentioned buy the two part putties. As far as the pin holes, folding the putty and hardener into each other will eliminate alot of that. Most people tend to stir the two together like paint, but what that does is actually introduce air into the mixture thus creating voids when applied. Cheaper quality fillers will also have alot of air in them straight out of the can, so buying a better brand filler may also help you.
TravisNeff
May 23 2005, 06:21 PM
QUOTE (Porsche Rescue @ May 23 2005, 02:41 PM) |
Travis is quick, also must be right 'cause he agrees with me! |
My girlfriend says I am, er uh nevermind
TimT
May 23 2005, 06:49 PM
well heres some of the shaved rain gutters shot with primer
TimT
May 23 2005, 06:50 PM
pinholios
TimT
and the 935
TimT
May 23 2005, 06:52 PM
I never noticed how much the rear wing deflects at speed
Wowsers!!
Lou W
May 23 2005, 07:18 PM
I use Evercoat Lite body filler, 3m Acryl Spot Putty for pin holes and scratches and SEM high Build Primer Surfacer. Never had a problem with shrinkage. However, too much spot putty applied too thick, would probably shink.
This is IMHO
Jeroen
May 24 2005, 05:08 AM
nice shot of the 935
I'll work on it this week and see what I can come up with...
914Timo
May 24 2005, 05:23 AM
It looks that your putty is too thick and/or you have put it too thick layer. But, I am no expert.
If I were you, I would go and buy some new putty and try it with several light layers. Oh, and dont forget to mix it well before use.
xsboost90
May 24 2005, 05:51 AM
i would use some metal glaze-evercoat- or they have a couple of other glazing puttys that are two parts. The stuff in a tube is basically just really thick laquer primer, and since laquer primer has a tendency to shrink real bad, so does the putty.
