Pinholes, nuther paint question |
TimT |
May 23 2005, 04:37 PM
Well I can build killer engines, weld aluminum, bend tubing for roll cages, grill some mean ribs, and even hang the bodywork on my car so the panels all line up nicely and the car looks "gud"
Im having to blend some areas where I removed the rain gutters and where I blend glass or cf to the steel base.. What do you do about the pinholes in the filler? I guess Im mixing air into the filler, so Ill mix more carefully from now on, but what about he pinholes I find when sandin? Do these get filler with primer/surfacer? or do I fill these with a light coat of filler? inquiring minds want to know (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
TravisNeff |
May 23 2005, 04:40 PM
I believe spot glazing putty is just the stuff for filling pinholes as you describe.
Porsche Rescue |
May 23 2005, 04:41 PM
Get a tube of body putty, think they call it glazing putty. Follow directions on the tube. Primer might fill but don't take the chance.
Travis is quick, also must be right 'cause he agrees with me! This post has been edited by Porsche Rescue: May 23 2005, 04:42 PM |
TimT |
May 23 2005, 04:45 PM
A paint guy told me under no circumstances use the stuff in a tube..but said with the new filler pinholes are basically a thing of the past
something about shrinkage (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Im just an occasional aquantaince with this paint guy, and feel like I have used up my advice quota from him... so here I am |
jasons |
May 23 2005, 05:01 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
There are 2 kinds. One that is a 2 stage epoxy hardener style and one that just sets up on its own. I know most guys say not to use the old style stuff that is not 2 parts. I have used both and I find the old stuff easier to work with. It was alot thinner and filled the imperfections better. I think if you don't try to fill big holes with it, you will be fine. Also, when you shoot high build primer, it will fill alot of those pin holes. If you use the good filler, like the Evercoat Rage, pin holes are minimized. All of that said, I aint no expert. Thats just my experience. |
Kargeek |
May 23 2005, 05:02 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
You can buy catalyzed skim filler- it's like bondo but thinner- use it like putty to fill imperfections and pin holes. No shrinkage. Dave H
sixnotfour |
May 23 2005, 05:06 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) The bobyshop, I snoop around in uses this , no problems. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) Tim, They did rdane's no gutter 911 on pelican,I am sure you've seen it. |
Jeroen |
May 23 2005, 05:27 PM
never had that problem...
are you sure the pinholes are in the filler and not in the f/g or cf? if you sand through the gelcoat, you'll end up with lots of pinholes if that aint it, all I can say is that you need to mix up the filler and hardner real gud |
TimT |
May 23 2005, 06:05 PM
No the pinholes are on the steel side of things Im trying to blend.. On the fiberglass and carbon fiber Im just knocking down the high spots with a long board and calling it gud..
oh BTW i have another pretty good shot of our 935 Ill email you |
scotty b |
May 23 2005, 06:16 PM
Under NO circumstances should you ever use the one part "glazing putty" that stuff if pure CRAP. As mentioned buy the two part putties. As far as the pin holes, folding the putty and hardener into each other will eliminate alot of that. Most people tend to stir the two together like paint, but what that does is actually introduce air into the mixture thus creating voids when applied. Cheaper quality fillers will also have alot of air in them straight out of the can, so buying a better brand filler may also help you.
TravisNeff |
May 23 2005, 06:21 PM
My girlfriend says I am, er uh nevermind |
TimT |
May 23 2005, 06:49 PM
well heres some of the shaved rain gutters shot with primer
TimT |
May 23 2005, 06:50 PM
pinholios
TimT |
TimT |
May 23 2005, 06:52 PM
I never noticed how much the rear wing deflects at speed (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Wowsers!! |
Lou W |
May 23 2005, 07:18 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
I use Evercoat Lite body filler, 3m Acryl Spot Putty for pin holes and scratches and SEM high Build Primer Surfacer. Never had a problem with shrinkage. However, too much spot putty applied too thick, would probably shink. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
This is IMHO (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Jeroen |
May 24 2005, 05:08 AM
nice shot of the 935
I'll work on it this week and see what I can come up with... |
914Timo |
May 24 2005, 05:23 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
It looks that your putty is too thick and/or you have put it too thick layer. But, I am no expert.
If I were you, I would go and buy some new putty and try it with several light layers. Oh, and dont forget to mix it well before use. |
xsboost90 |
May 24 2005, 05:51 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
i would use some metal glaze-evercoat- or they have a couple of other glazing puttys that are two parts. The stuff in a tube is basically just really thick laquer primer, and since laquer primer has a tendency to shrink real bad, so does the putty.
Lo-Fi Version | Time is now: 20th May 2024 - 09:11 PM |
