QUOTE(simonjb @ Nov 27 2017, 12:38 PM)
I've read a bunch of posts on this but I am still not getting how to remove and replace the roller for the trunk. I have made a notch in an adjustable spanner/wrench.
What I don't understand is what do I lever the wrench off/on to so that the spring bar will lift off the roller so that I can remove and put the new one on?
Click to view attachment Thanks!
Just did this job last week to both sides and the torsion bars were unloaded to boot. It is a job and one that should be done with safety in mind. I tried the socket on the end of the torsion bar routine and almost took off my ear. I replicated a tool that was shown to me and I call it the "enabler" It hooks around the torsion bar in the area of the bends of the bar. If your torsion bars are unloaded then follow below procedure.
Assemble "Enabler" onto the torsion bar by way of the 3/8 slot with the slot facing toward the outside of the car. Pressure then toward the front of the car will bend or load the torsion bar. The tool can't go flying off into space as it's hooked on the torsion bar. The procedure is actually a three step process. First load the torsion bar moving it about half way to its final position. Have a helper ready to slip a solid piece of metal or hardwood under the first large bend keeping their hands clear. Remember safety. This holds the bar in a partially loaded position. Relax the pressure on the tool and move it further DOWN the torsion bar toward that first big bend. Getting it past there is even better. Now comes the hard part. Put the biggest guy on this - push the tool toward the front of the car thereby loading the torsion bar once again from this new position. Once past the axle of the roller have your helper coax the torsion bar around on to the other side. Relieve the pressure on the torsion bar slowly ensuring the torsion bar stays where it's needed. Rest a minute or two or three. Your almost there. The hard part is done. Lastly ensure the "enabler" is at the bottom most point it can be and load the torsion one more time moving the tool toward the front of the car enough to where your helper can slip the roller onto the axle shaft. Use a pair of pliers or other such tool for this DON"T use your hands. Slowly relieve the pressure ensuring the torsion bar is caught in the groove of the roller. Side one done. Move to other side and repeat.
if your just replacing the rollers the job is much easier. Just move the bar as described above in the last step to enable the removal and replacement of the roller. I used the aluminum rollers rather that the plastic ones. Found them on ebay.
When done go drink a beer - that's the fourth step in the process.
By the way the angle of 30 degrees at the handle end is to make room for your hand up against the bottom side of the trunk lid. Bend it the other way for the opposite side of the car. Use a BIG vise and BIG bar to bend the handle in the opposite direction. Material of the tool needs to be hard enough to withstand the forces required w/o bending (too) much. I used SS. It does get beat up doing this job, I still have it in a usable condition and if you want to borrow it PM me.
Lastly there is the possibility of removing paint in this area. I readied a number of 1/8" thick pieces of wood and used them as protectors for my paint job.
Hope this help.
