QUOTE(McMark @ Jan 15 2018, 06:26 AM)
QUOTE(holtby914 @ Jan 14 2018, 05:32 PM)
I bet many people told you, that what you were doing was crazy, but that didn't seem to stop you either
You completely misunderstand. I'm not saying you can't or shouldn't. I'm saying the chassis is more important, and the bottom line of what I'm saying is that you should focus on that exclusively first. But you're FULLY capable of doing a turbo build. It's not rocket science. I'll gladly help. I'll share everything I know. But I've seen a lot of newbies come through here with grand ideas, only to get burned out, stalled, and give up.
If you wanna jump on it all right outta the gate, lets do it. What do you want to know?
I used a K03 turbo off of a 1.8VW/AUDI engine for my engine. I built a custom exhaust header using prebent piping from Summit Racing. I chose to put the turbo up high to allow for gravity oil drain and that worked fine for me. It also kept plumbing to a minimum. I'm running about 7lbs of boost and because of the small turbo there's no noticeable turbo lag. It's just always there. During testing and fiddling with the turbo settings I saw boost as high as 1bar. Didn't blow anything up right away.
You're going to be dealing with heat if you're trying to make big power from a small engine using a turbo. And unlike water-cooled cars, there's not much you can do that isn't fantastically expensive. So you have to give up some potential (in my opinion) to play it safe.
I think fuel injection is necessary for a well built turbo engine. Carbs can be run, and people have done it successfully, but it's always a bit of a hack.
So what else do you wanna know?
The chassis is what I am working on right now. I am in second year, and will have to complete a big project in 4th year called capstone. SO what my professors have suggested is to try to get everything else on the car fixed, then come forth year I will spend most of my time on the engine component.
I was given a k03 off an a4 as well and was planning on using it. Found a $50 rebuild kit on eBay...
It is so cold outside right now, however, that my time is better spent learning (it's really amazing how much you can learn from some books) and planning right now, rather than freeze and getting frustrated outside. Just reading your turbo thread has taught so much. My apologies for the misinterpretation.
Fuel injection is definitely what I am going to do. Thank you to "mueller" for convincing me:)... excited to learn how to use and build megasquirt.
Heat is a concern, someone above mentioned I should try water-math injection to help keep temps down... What do you think about this? Also going to use forged JE pistons, just to be safe, and of course a big oil cooler was always going to be part of the plan. I have done some sketches of a turbo system for a 914 (did it for a design project in first year), that I will post when I get the chance. They are pretty basic, nothing special, but gives a good idea of how I'd like the setup to be.
I will have questions for you periodically, trust me. I'll also say that I completely understand tons of people come on here and say they are going to do incredible things, and end up failing. I am very determined with this car and I promise I won't give up until it is everything I say it's going to be. It means everything to me.
Thanks for the help and support, this isn't the last you've heard of me!
Blake
P.s. I posted a link bellow with a youtube video my friend made with me, that i talk about the build in. He has a youtube channel, and has suggested we do periodic "build updates" every few months.
