camgraves3113
Mar 6 2018, 08:36 PM
THANK you everyone, me and my dad were able to drop it out without even cutting nor drilling any bolt whatsoever. So i had the car up on 1 cinderblock high, and basically, using two jacks on either side of the engine mounting large bracket. Bye doing this, there was no down pressure on the bar which was ultimately holding the nut in the deepest part of the oddly located and shaped (cover?)-holding the nut and bolt on either sides. BECAUSE of this, i was finally able to get my hand and a wrench on the nut, and a socket on the bolt.
Also bye jacking the bar, with two jacks close to the middle (leaving the bolt and nut accessible) basically, only the top of the bolt is threaded, so i was able to push up on the bolt, and push it in farther, allowing the nut to be raised and provide easy access. Sorry if i am hard to understand, i am surely not majoring in english!! Haha
All in all, i am very thankful for the 914 community and support, as i was able to make huge progress today. Now i get to work with the motor and get the baby cleaned out (it is a bored out 1.7L to a 2litre) and looking and sounding good. In the next few posts i am going to provide images to respresent my directions ^ and hopefully make this adventure more informative for whomever reads this thread
camgraves3113
Mar 6 2018, 08:37 PM
2
camgraves3113
Mar 6 2018, 08:38 PM
3
camgraves3113
And 4
jd74914
Mar 7 2018, 09:16 AM
Awesome! Looking good Cam. Much cleaner than the first time I pulled my '74 motor.
Planning on converting to 5-lug (looking at the 911 hubs in the background)?
camgraves3113
Mar 7 2018, 12:39 PM
QUOTE(jd74914 @ Mar 7 2018, 10:16 AM)
Haha yes you know it! And thank you, im excited to finally get to the nitty gritty and try to get the most powerful 4cyl as i can
Dave_Darling
Mar 7 2018, 01:31 PM
QUOTE(camgraves3113 @ Mar 6 2018, 06:36 PM)
That is commonly referred to as a "1.9" or a "1911" (which is the displacement in CC of a 96mm bore and the stock 66mm stroke).
A 2.0 motor is 94mm bore X 71mm stroke, for 1971cc displacement. Calling your 1911 a "2 liter" is a bit of a misrepresentation.
--DD
camgraves3113
Mar 7 2018, 01:57 PM
QUOTE(Dave_Darling @ Mar 7 2018, 02:31 PM)
--DD
Very interesting, as i will admit i at this point i am very ill informed regarding engine specifications, compression rates, and ect. Thank you for pointing this out I appreciate any info you have to offer
camgraves3113
Mar 8 2018, 03:05 PM
Gosh this looks AND smells horrible!
The engine tin and especially screws are so corroded and stuck i can barely move ANY of them! Yes i used tons of liquid wrench, and gave it time to sit. Any ideas? Thanks!!
camgraves3113
Mar 8 2018, 03:06 PM
I definitely have to get my tetanus shot now
camgraves3113
Mar 8 2018, 03:07 PM
And lastly, this grease covored oily mess
jd74914
Mar 8 2018, 03:34 PM
Those RH intake ports don't look so hot...is that white stuff corrosion and does it run the whole way down the port?
camgraves3113
Mar 8 2018, 04:00 PM
QUOTE(jd74914 @ Mar 8 2018, 04:34 PM)
Sadly it is corrosion, and from what i can tell, the engine is basically filled with it; including all the way down the port
camgraves3113
Mar 8 2018, 05:39 PM
Worked on cleaning it up with purple power luquid, metal bristled brushes, and some elbow grease. Got to admit, it barely seems to look any better. I wish i could power wash it, or would that be too harsh to the crevices of a bare engine? Any tips or tricks would be great
Dave_Darling
Mar 8 2018, 06:35 PM
For the engine tin screws, I have found a few things that help.
1- Get the correct size screwdriver. I know they're just slot-head screws, but if you get a driver that fits the slot snugly it helps. I found that the largest screwdriver I could find at my local Sears was the correct size. If you can, take one of the engine tin screws with you to check the fit against the screwdrivers in the store or in your Best Friend's tool collection.
2- Impact can help. Put the driver in the screw, then give the handle end of the driver a sharp rap with a mallet. This can, sometimes, help break a bond between the fastener and what it is screwed into.
3- Use a good penetrating oil. Liquid Wrench is OK, WD-40 is not. I like PB Blaster and Kano's Aero Kroyl. Others have said that paraffin also works if you heat the fastener.
4- Which leads us to the other big thing, heat. The "hot wrench" can help break the bond between parts. Use with caution, and make sure to have a fire extinguisher handy.
--DD
Mar 8 2018, 06:42 PM
Lots of heat and then the paraffin/wax as it cools. The heat wicks in the wax. Works well.
porschetub
Mar 8 2018, 09:25 PM
QUOTE(jd74914 @ Mar 9 2018, 10:34 AM)
not good don't expect too much ,outside stored motor,generally not a great out come,bottom end might be ok???
In this case I would say the pistons will be seized in the bores
camgraves3113
Mar 8 2018, 10:42 PM
Thank you guys so much, i will try all the suggested techniques, and update you all on the outcome!
jd74914
Mar 9 2018, 07:07 AM
I'd highly suggest going out and buying an impact screw driver to remove engine tin screws (also work well for the rotor screws, etc). When you hit them with a hammer they rotate slightly so the turning is perfectly timed with the impact; I've rarely stripped a tough screw using one. You can buy Lisle 3/8" one at sears or off Amazon for ~$20 and it's worth every penny.
camgraves3113
Mar 9 2018, 06:37 PM
Sadly on the other intake, some bolts are stripped, and i am currently trying to get them out
camgraves3113
Mar 10 2018, 06:40 PM
Also, for everyone that is interested, i have some 914 things up so far, but i am about to offer many more parts (refurbished) on ebay!!
Here is my link;
My Webpagehttps://ebay.com/usr/cagrave-0
camgraves3113
Mar 10 2018, 08:59 PM
Also, is it correct for the intakes farthest nut (closest to the tranny) to be a different size? It could be that mines so rusted and deformed, but it seems to me to be genuinely smaller than the other three 13mm bolts that bolt the piped on. Im just curious!!
camgraves3113
Mar 11 2018, 01:25 PM
Still have yet to touch this guy!!!! Haha, the parts are beautiful though i am very excited to eventually get to it
camgraves3113
Mar 13 2018, 02:07 PM
Does anyone have a pro and con list of shocks and struts compared to the price. I want to go with KYB gas adjust, is that ok for performance?
Mar 13 2018, 02:31 PM
QUOTE(camgraves3113 @ Mar 13 2018, 04:07 PM)
No. If you want performance shocks, go billstein or koni. If you want economical and good street driving go Boge. If you can only afford kyb’s, save your money until you can spend more.
camgraves3113
Mar 13 2018, 10:49 PM
QUOTE(mepstein @ Mar 13 2018, 02:31 PM)
I appreciate it. I do have the money, but i dont really understand the difference in the shocks and struts from one to another
3d914
Mar 14 2018, 01:16 PM
QUOTE(camgraves3113 @ Mar 13 2018, 09:49 PM)
I second mepstein's advice. Went with Billstein and never regretted it.
camgraves3113
Mar 16 2018, 01:11 PM
Trying to get better at refurbishing parts in general. I am pretty excited about this blower/heater
camgraves3113
Mar 16 2018, 01:12 PM
Another pic
camgraves3113
Mar 16 2018, 01:13 PM
3..
camgraves3113
Mar 25 2018, 05:35 PM
This looks good right?
