So I finally started digging into my 320i caliper that had the busted-off bleeder valve last night. I figured I'd get it off of there, drill the old one out, 'Easy-Out' the old one and get her back on the road. Boy did that sound a lot easier than it was!
After a long ordeal to get my DF rim off the car, I was in the business of taking my caliper off. No problems there! I drilled out the FIRST easy-out that broke off inside the caliper. Evidently, I didn't learn my lesson. The next one broke off in there too! Now I'm pissed...grab the Dremel, and start to put a line in the whole mess to take it out with a screwdriver. 5min later, it looks like this ( | ) so I'm off to the races...not. That broke too, so NOW it looks like this. | } Crap...maybe I'll go to the old calipers...
So I look at them...WAY worse than I remember. The pads are 3/4"thick at the top, and 1/8" on the bottom. That aint going to cut it...I scream into the night..."WHERE IN THE #$%@ AM I GOING TO GET A SET OF MACHINED 320i CALIPERS AT 10:00pm IN CLEVELAND!"
not 30sec later, Samson calls me to see if I need help with the optical ignition that I wanted to do.
Doug: "Don't you have a set of 320i calipers that you aren't using yet?"
Samson: "Yeah, but they are on the west side..."
Doug: "Can I come get them?"
Samson: "I'll be home in 20...see you there."
I got there before HE did...to take possession of a rebuilt set of machined 320i calipers! I paid the man, thanked him kindly, and was on the way back to the house to finish the deal.
And you Cali guys think you have all the cool friends!
Here is the question part...
I got them put on the car, and bled the lines my self with the power-bleeder. Then again with my wife, then again this morning. I'm STILL not getting the braking that I think the car is capable of. I have a NEW 19mm master, replaced all the rubber lines, all the hard lines from the rubber to the calipers, new Metal Master pads, and have bled the system 5 times...still takes me forever to stop. I've got a "T" for the rear that I'll do later tonight, but Im out of ideas...
Anyone???
