QUOTE(mepstein @ May 22 2018, 11:47 AM)
QUOTE(mb911 @ May 22 2018, 03:18 PM)
I really like it.. Now I need to source the kit or material.
The kits are pieced together but only seem to come in grey. I want black.
914rubber has perlon for a good price and your choice of backed or not. I believe you want to buy the non backed perlon because it will stretch and mold around the firewall. I’m using some self adhesive rubber soundproofing that I bought on amazon. It’s pretty thick so I will spray adhesive and lay the perlon directly on the rubber. I also have to grind off the clips that hold up the backpad and maybe fill the screw holes.
When I bought my perlon carpet set from Mike I just asked for extra material to do the firewall. He sent me an extra piece of matching perlon with no backing. I put it on over sound deadening material using spray adhesive.
The only part in the least bit tricky is the joint of the carpet up against the window. I made a template out of a bunch of pieces of paper taped together and then put that on the fabric to match the profile of the window.
otherwise the unbacked perlon forms easily to the contour of the firewall with no wrinkles. piece of cake.
For lighting I cut a 911 light in down low on the firewall just above the tunnel. works great.
