QUOTE(burton73 @ Feb 26 2018, 06:08 PM)
My 6 when I got it had a u clamp over the tube and 2 thin nuts squeezing the tube to the left side of the tunnel. I guess it worked but I fixed it by welding a bracket over it when I had it apart.
Question is how far do you want to go in?
Bob B
YEP.... that is what a PO did with mine. U-Bolt thru the floor pan holding the tube at just about the place that the bracket was. along with several door knob holes in the top of the tunnel. Guess he was hunting where the problem was.
Along with welding a 1/4" thick 2" x 2" piece of steel on the outside firewall. They cut a notch in the plate so the tube would sit in it.
I have been 40K miles of daily driving with this shade tree fix. Pretty difficult to fix "right".
