QUOTE(Chip @ Feb 27 2018, 09:36 PM)
Is the "Right passenger inner wheel house firewall" the proper part to repair
the rust holes deep in the bowels of the hell hole? Beneath the battery?
1. It's not really as simple as your question makes it seem.
2. It's not a one day or weekend repair.
3. You will likely need to disassemble much of it with the door gap braced to make welded repairs, likely using a number of pieces of reproduced steel from places like Restoration Design.
4. If you can weld and have the time, shop space, and materials it can be rewarding. It will usually not make you money unless it is someone else's car.
I did both sides of two cars by removing rocker, jackpoint, and cutting out bad steel from inner rocker and some of inside longitudinal, repairing to original thickness, and then adding what is often known as an"Engman longitudinal stiffening kit" paying tribute to one of the early developers of this technique for a 914. There are other similar products now made. Along the way there will be repairs needed to the bottom of the inner and outer engine firewall, as well as to the floor pan and the rear jacking triangles. See pictures.
Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=640
980]
