D1A3
Jun 5 2005, 08:56 PM
I'm familiar with the factory DPD/VPC setups and also those from ICEAC and Vintage. The question I have is if anyone has put A/C into their car without cutting the floor out of their front trunk? Basically, is there a way I can get A/C into my car without cutting out major sheetmetal?
Thanks,
Jason
messix
Jun 5 2005, 09:04 PM
bungee cord it to the bumper?
Dr Evil
Jun 5 2005, 09:08 PM
Not sure, but the most modern kit is made by a shop in TX...If I find more info I will post it, if not someone will say something.
Bump
914GT
Jun 5 2005, 09:09 PM
Jason, basically your options are limited on these cars on where to locate a condensor. Up front is the best place to get the coolest airflow and I don't know of anyway to mount it effectively without cutting holes in the trunk. The rear wheel wells might work but air circulation would be a lot worse and the condensor exposed to debris flying off the tires, unless you could shield it somehow. The rear trunk means cutting holes again, and it's a hot location close to the engine.
