Eddie914
Jun 6 2005, 04:31 PM
What are good sources for an oil thermostat for a 2.7/6?
I'm using a front oil cooler with -12 size oil lines. The oil tank is located where the stock battery used to be located with the oil running through the passenger side rocker panel.
What thermostat is this on Stratplayer's 914? A setup like this this would be perfect.
Thanks
Eddie
J P Stein
Jun 6 2005, 04:46 PM
I'm a fan of the Troutman thermostat. It uses the same element as your 9eleben motor....with a pressure relief valve.
Here's my mounting.
TimT
Jun 6 2005, 04:49 PM
You can get the Mocal thermostat at Pegasus. Bat Inc,etc...
J.P's is available from Troutman
