Source for oil thermostat for 2.7/6? |
Eddie914 |
Jun 6 2005, 04:31 PM
Unregistered |
What are good sources for an oil thermostat for a 2.7/6?
I'm using a front oil cooler with -12 size oil lines. The oil tank is located where the stock battery used to be located with the oil running through the passenger side rocker panel. What thermostat is this on Stratplayer's 914? A setup like this this would be perfect. Thanks Eddie Attached thumbnail(s) |
J P Stein |
Jun 6 2005, 04:46 PM
I'm a fan of the Troutman thermostat. It uses the same element as your 9eleben motor....with a pressure relief valve.
Here's my mounting. Attached image(s) |
TimT |
Jun 6 2005, 04:49 PM
You can get the Mocal thermostat at Pegasus. Bat Inc,etc...
J.P's is available from Troutman |
Lo-Fi Version | Time is now: 28th May 2024 - 03:47 AM |
