mmascari
Apr 7 2018, 12:53 PM
I know this topic has been beat to death but I need some guidance on my headlight issue. I think it is unique. Anyway, my headlights pop up and the lights turn on but as soon as I push the knob in to turn them off the headlights do not go down.....I have to manually turn the knob on the motor to get them down. ??
Steve
Apr 7 2018, 12:57 PM
Try swapping the relay from side to side.
Wyvern
Apr 7 2018, 01:00 PM
Both of them , or just 1 ?
Have you tried plugging in a different round relay ?
You could borrow one from the engine bay block to test it.
I will be at the PCA Diablo Region Porsches and Pastries tomorrow in Pleasanton.
Come on out and I'll be happy to give it a quick look at .
10am Sugaree Bakery, on Bernal
mmascari
Apr 7 2018, 01:01 PM
QUOTE(Steve @ Apr 7 2018, 11:57 AM)
They pop up OK just don't go down. I figured that meant the relays are good.
I had this on one headlight. It was a faulty relay.
mmascari
Apr 7 2018, 02:53 PM
QUOTE(JFG @ Apr 7 2018, 01:33 PM)
Oh OK, didnt realize that the relay could still be faulty if they pop up. Neither go down.
mmascari
Apr 7 2018, 02:54 PM
QUOTE(Wyvern @ Apr 7 2018, 12:00 PM)
OK, maybe I will come by. Look for my silver 914.
jim_hoyland
Apr 7 2018, 06:47 PM
Had a similar issue; turned out a tiny wire became disconnected from a diode. There are pics posted
jim_hoyland
Apr 7 2018, 06:50 PM
Like this, not easy to see....
jim_hoyland
Apr 7 2018, 06:51 PM
Like this, not easy to see....the black plastic covers one, the second one is uncovered. Some have soldered them in place. You can remove the entire motor to get better access
mmascari
Apr 7 2018, 10:36 PM
QUOTE(jim_hoyland @ Apr 7 2018, 05:51 PM)
So did you have the same problem......headlights would not go down...and it was a solder issue on the motor?
toolguy
Apr 7 2018, 11:38 PM
Both headlights, doing the same thing. . I'd look at the green lead from the headlight switch which puts battery to the 'down' circuit. . most likely the switch
ClayPerrine
Apr 8 2018, 07:07 AM
If it has been more than 4 hours seek medical help.
Seriously.... I have a diagram on how the headlights work.
How your headlight motors work.If it is both headlights, it may be the headlight switch.
jim_hoyland
Apr 8 2018, 07:13 AM
Clay; Great diagrams. Where are the diodes ?
jim_hoyland
Apr 8 2018, 07:17 AM
QUOTE(mmascari @ Apr 7 2018, 09:36 PM)
One of the wires on my HL motor to a diode broke away. You can diagnose it if you have good access to the motor and those wires. I took a thin screwdriver and pushed the small wire onto the spot is was connected. Presto ! the motor came on and the bucket closed.
If the diodes are still connected, then it's gonna be a different issue.
mmascari
Apr 8 2018, 10:02 AM
QUOTE(toolguy @ Apr 7 2018, 10:38 PM)
Thanks for that....I will check the green wire on the headlight switch.
mmascari
Apr 8 2018, 10:30 AM
I believe I found the problem...I checked the green wire on the drivers-side motor and as soon as I touched it, it broke off from the motor. Can I just solder it back on?
