pfierb
Jun 7 2005, 06:50 AM
The speedometer needle jiggles around untill it reaches 35 mph and then smooths out on my 1973 914,any ideas ?
Thanks Paul F.
ThinAir
Jun 7 2005, 07:01 AM
When mine had this kind of problem it was due to grease inside the speedo that was coming from the cable. I had a leak at the angle drive on the tranny that was allowing tranny fluid to go into the cable. It wicked up the cable and into the speedo. To fix it I had to have a speedo shop clean out the speedo, replace the cable and fix the leak.
In the end I gave up on stock speedos and bought a VDO electronic speedo so that I can calibrate it to give me accurate readings regardless of what size tire I switch to.
Rouser
Jun 7 2005, 03:33 PM
Your cable has a kink in it. Not so much just the outside sheath, but the cable inside too.
You can go ahead and chase a number of other options, but they'll eventually lead to replacing the cable.
It's 30+ years old; replace it.
redshift
Jun 7 2005, 05:31 PM
QUOTE (ThinAir914 @ Jun 7 2005, 09:01 AM) |
In the end I gave up on stock speedos and bought a VDO electronic speedo so that I can calibrate it to give me accurate readings regardless of what size tire I switch to. |
Is that a classic thread somewhere?
M
ThinAir
Jun 7 2005, 11:02 PM
QUOTE (redshift @ Jun 7 2005, 04:31 PM) |
QUOTE (ThinAir914 @ Jun 7 2005, 09:01 AM) | In the end I gave up on stock speedos and bought a VDO electronic speedo so that I can calibrate it to give me accurate readings regardless of what size tire I switch to. |
M |
Nope. It was pre-914World.com. MidAmerica Motorworks has one in their catalog for VWs just to give you an example. Here is a copy of the installation instructions just to give you an idea of how it works.
My recollection is that I bought the VDO 4" speedo, the bought a GM sender like this and had a speedo shop make up a short cable to attach the sender to the angle drive gear.
North Hollywood Speedo carries the speedo and they have a page for the senders also, but no pricing listed. The VW kit is $200, but I've not seen the 4" speedo for a 914 in kit form.
Do a web search for "VDO Programmable Speedometer" and you'll probably find even more stuff.
It's an upgrade that I can definitely recommend!
