So 12v and e.g. 100 amps from a high output alternator is unfeasible?
You'll want to run #00 welding cables from the alt to the battery and from the battery to your heater...
--DD
For 1200 watts? Of course you would have to leave some of that behind for the other needs of the car. Step it up 110 with an inverter on the way and the wiring could be an extension cord. Which brings me to the Honda generator in the trunk idea. Small household space heater in the car.
Another idea is to put the webasto in the right rear wheel well and duct into the existing air system.
I want to go to WCR across the Rockies from me. Will I make it without a heat exchanger? The front fan works, and I can bundle up, but I do want to see ahead.
