QUOTE(Mark Henry @ Apr 22 2018, 12:46 PM)
I'm assuming stock SC dizzy?
First thing I'd check the green wire on the dizzy, on an SC it often breaks at the mount then flexes till the copper wires break.
Other causes, stock CD dieing, cracked cap, pick up dieing, dizzy bushings shot, rotor resistor shot, bad ignition wires, coil.
Thanks for your expertise Mark.
It is the stock dist. The green wire is new but I am wondering if it is not making contact in the dist properly. I have MSD ignition module, new wires, new coil, etc.
