Finally made the brackets and installed the stock fog lamps, but I blew two 16 amp fuse blows when I turn on the lamps.
I checked the lamps with a 12v battery out side the car and also checked to make sure that I had 12 volts into the fog lamp harness in the trunk everything checked out.
Is it possible that the bulbs are drawing too much current? Is it safe to measure the current at the fuse block w/o the fuse using a DVM?
Thanks,
Dan
