A Porsche 356 owner contacted me about converting a set of Marchal fog running lights to LEDs. We talked about it and he asked if I could do it in 6 weeks. My response was I've never done a high power LED headlamp so it's more of a project than a product.
The Marchal running light is shown on this file-folder picture of a 356. That's not me nor the owner.
Click to view attachment The idea was to design an LED-only board attached to a large heat sink and use a step-up dc-dc converter on a separate board to provide 0.275Amp to the LEDs.
The LEDs are Cree XP-G3 surface mount LEDs. These have a maximum current of 2 amps. The LEDs require a lens to focus the light pattern. The XP-G3 have a wide output light pattern and can't be used 'naked'. The lens per LED are Carclo's 10049 lens with a light pattern shown below.
Click to view attachment The LED board uses 19 LEDs with lenses and holders. The board will be backed by a very large heat sink. The main killer of LEDs is heat. 2 amps through an LED with 3.5V is 7W in less than 1/4" square area. Massive power dissipation/heat in a very small area.
The PCB really should be an aluminum PCB but they are really expensive so the PCB is FR4 and is thin at 0.8mm to minimize thermal impedance of FR4. Vias from top to bottom are liberally applied to provide as much metal top-to-bottom for heat transfer. The clear area of the bottom of the board will allow maximum heat flow to the heat sink.
Click to view attachment Click to view attachment
