QUOTE(Vacca Rabite @ May 13 2018, 08:57 PM)
There are so many potential issues here before you even get into the workings of the transmission.
Are you asking about clutch adjustment (the pedal you push with your feet) or shifter adjustment (the lever you move with you arm). It sounds like you are asking about the shifter, and not the clutch.
How are the bushings? Do you know if they have ever been replaced or upgraded? Worn out (and often missing) bushings can make shifter adjustments very difficult.
You adjust the shifter with the stick on. You find the 2/3 plane and work from there.
Zach
You’re right. It’s not the clutch but the stick. But how do I get the shifter back to its normal placing. It’s off somehow cause it keeps going in reverse. I don’t know if I need to pull the rod forward and then back or what. Thanks for the advice though.
