QUOTE(porschetub @ May 24 2018, 03:53 PM)
QUOTE(Rob-O @ May 25 2018, 05:52 AM)
I believe this is for side shifter/73-76 cars. Not sure if it works on the early cars.
I bought this a few years ago while rebuilding the shift linkage. I also had a new factory style bushing for the firewall. It had no slop so I installed that instead of using this. Comes with the rivets and the directions on how to install. I fitted it up to the car and shift rod but never that’s as far as I got.
$35 shipped to lower 48.
-Rob
Knew that wouldn't last long,unsure why the seller didn't fit it they work great.
***SOLD***
Agreed that it looks like a great upgrade, but I’m just super weird about drilling any holes in my car. I knew I would need to drill in order to install it but then two things happened. The first was that the directions say in some rare cases you may need to shave down part of the shift union at the firewall if you can’t get 1st, 3rd and 5th to work. It was hot as hell here in Texas and I just knew I’d be that rare case.
Sounds like no big deal until you realize you have to pull the shift rod off again, make the mod, find new rivets, order a new set screw for the shift rod. The second was that I already had a new stock style bushing on hand and I figured I’d give installing it a shot. I had no slop when I installed the stock bushing so I just went with it.
