914Sixer
Jun 4 2018, 03:57 PM
As you know I am looking for a passenger 914-4 Bilstein strut. Mark E suggested I call DC Automotive. So I did. Well the seller on the other end of the line told me he had been doing it for 25 years and that he had never heard of such a thing. I assured him that I had two drivers sides and that they were real and they had a 3" brake caliper pattern. Seller was again polite but indicated I was nuts. I said thank you and went on.
I found it amusing. I hope that I am able to learn something new everyday. Still working on being a know it all after all these years.
Chris914n6
Jun 4 2018, 05:02 PM
914s only came with Boge struts. I believe Bilsteins were optional on 911s or part of the race program (still 5 lug).
Have you fitted a hub and caliper on it?
Jun 4 2018, 05:53 PM
I thought you could get a billstein insert as an option but I’ve never seen a billstein 914-4 strut.
Rob is a good guy. His first Porsche was a 914 with a Mitcom body kit. He just sold it to one of his employees. Unfortunately, he no longer carries many 914 parts. Out of 140,000 sq/ft (not a typo) only about 400 sq/ft are 914.
JeffBowlsby
Jun 4 2018, 06:17 PM
Bilstein struts were an available 914/4 option. I have a set, special PN.
Jun 4 2018, 06:18 PM
QUOTE(Jeff Bowlsby @ Jun 4 2018, 08:17 PM)
I believe you. I've just never seen a set in the wild.
JeffBowlsby
Jun 4 2018, 06:32 PM
914 341 091 34
914 341 092 34
Mine need to be stripped and repainted.
914Sixer
Jun 4 2018, 06:43 PM
There is a set for sale in the classified section. Added pictures from classifieds. Mine are over in the warehouse.
Jun 4 2018, 06:45 PM
QUOTE(Jeff Bowlsby @ Jun 4 2018, 08:32 PM)
914 341 091 34
914 341 092 34
The bearing surface on the spindle may be too far gone unless that is just light surface rust.
914werke
Jun 4 2018, 07:00 PM
as do I
Still looking for a source for the seals & hw to rebuild otherwise Id put them back on the LE.
Jeff could confirm but I thought there was an actual option pkg/code from Porsche.
914Sixer
Jun 4 2018, 07:04 PM
You can use 911 inserts.
914werke
Jun 4 2018, 07:07 PM
Mark to your orig theme, I had a similar experience recently talking to FAT.
Made contact re sourcing someone to do the dual plug machining for my next build
And spoke with some yahoo who claimed they'd never done it never heard of it outside
of light aircraft and couldn't understand why ..."seems like a total waste of money"
Jun 4 2018, 07:17 PM
QUOTE(rdauenhauer @ Jun 4 2018, 09:07 PM)
My 2004 Dodge Durango has dual plugs.
r_towle
Jun 4 2018, 07:28 PM
Have you tried Brad in Illinois, or Rick at HPH in the Bay Area?
Mark Henry
Jun 5 2018, 06:59 AM
QUOTE(mepstein @ Jun 4 2018, 08:45 PM)
914 341 091 34
914 341 092 34
You can get them chromed (not the pretty chrome) or use a Speedi-sleeve.
A crank machine shop should be able to do this.
JeffBowlsby
Jun 5 2018, 09:30 AM
its just light surface corrosion. A brillo pad will take it off.
Contact/send them to Bilstein directly...in SoCal if I recall...they will rebuild them.
rhodyguy
Jun 5 2018, 03:17 PM
There's a well optioned 2.0 75' up here with green units on all 4 corners. 'Option' on the window sticker. Cool car.
mtndawg
Jun 5 2018, 03:42 PM
QUOTE(Jeff Bowlsby @ Jun 5 2018, 08:30 AM)
Yes, I had a set rebuilt by Bilstein for a 911 and they looked very nice.
davep
Jun 23 2018, 05:28 AM
I have a set on my LE, but not sure that they are original since the rears are yellow. Also have a spare set of Bilstein's awaiting a project. I understand that factory installed rear Bilstein are green.
914Sixer
Jun 23 2018, 05:47 AM
The original factory rears were green.
JeffBowlsby
Jun 23 2018, 09:04 AM
QUOTE(914Sixer @ Jun 23 2018, 04:47 AM)
dr914@autoatlanta.com
Jun 23 2018, 09:11 AM
As Jeff stated, green Bilstein front struts and rear shocks were an option 73-76 914-4 models, and are also in the factory 914 parts book
KELTY360
Jun 23 2018, 01:40 PM
$150 option. Cost more than adding F&R sways.
Click to view attachment BTW, this window sticker soon to be for sale...including matching car.
Jun 23 2018, 02:17 PM
Please let me know I would be interested in this car
QUOTE(KELTY360 @ Jun 23 2018, 12:40 PM)
