Full Version: Very early 2.0 I think?
914World.com > The 914 Forums > Originality and History
greatworthclassics
Hello my name is Angus. I run Greatworth Classics over here in the UK. We are a classic VW & Porsche garage & restoration specialists.
We just picked up a 914-4 project car. Its a very early 2.0 built in September 1972 according to the fed sticker
Vin# 47329 01965
Is there a register for these cars in date of vin# order? I'm just wondering if there are many earlier cars known of?
Mblizzard
Look here
http://www.914world.com/specs/chasnrs.php
Tom_T
Cheers Angus!
Mine 73 2.0 is VIN....1854, VIN sticker dated 8/72, & Chassis # translates to 8/31/72 build date.
But another member had an earlier VIN with Sept. VIN & chassis # dates - so the VINs & sticker & chassis numbers don't always track anywhere close.
The other numbers to look at are the engine case # (GA or GB for 2.0s), & transaxle no. - both of which ranges are listed in the 914 Info section at the button at the top right of the 914world webpages.
Click to view attachment Click to view attachment
Your chassis number should be stamped on the rear trunk floor near the back wall, & on the Karmann Plate at the driver's side front doorjamb (it also has the paint color code in the bottom info box) - & both Chassis Nos. should match - as should all 4 VIN number locations (top of RF wheelhouse & plate @ RF headlight box inside the front trunk, tag at the L windshield frame, & sticker in LR doorjamb) - to verify that the original car is intact.
Use a 1972 calendar & start you week count with Jan 1 as week #1 (even if only 1 day in that week), then use the graphic below to figure out your chassis no build date.
Note that the 5 in 95 can change to 96, 97, etc. - in order to indicate 100s & 200s etc. + last 2 digits for the car # built that day.
Either way - it sounds like your project 914 is an early MY `72 2.0 or 1.7, & if originally sold in the USA, then it would've almost certainly have been equipped as the "914S" (or "914SC" in the UK market) with both the Appearance Group & Performance Group of options included in the base price (see "914S" & "914SC" info at link below).
http://www.914world.com/bbs2/index.php?showtopic=107851
In addition to the VIN link above, there are a couple of topics on here about the first 1000 73 914s which were built with some 72 parts mixed in (as were at any changeover MY), as well as Porsche/VW's experimenting with putting the black pebble-texture vinyl from the rollbar & sails - also on the windscreen frame top & sides (or extending to perhaps first 2000+/- or so, since my 1854 had the windscreen frame vinyl).
So google for that topic, since I've lost my link to the 2 topics on the early 73 windscreen frame vinyl, & then look into the nooks & crannies of yours to see if you can find any remnants on yours, since it's a unique oddity.
A couple of other 914 history websites which will be treasure troves for you are p914.com (&.net & .org), and the infamous Jeff Bowlsby's websites below:
http://bowlsby.net/914/Classic/
http://bowlsby.net/914/CanAm/
http://bowlsby.net/914/WiringHarnesses/ < also has wiring diagrams etc.
http://bowlsby.net/914/PartsFS/
welcome.png .... and .....
Tom
davep
here is the page for lists:
http://www.914world.com/bbs2/index.php?act=membervins
The 2.0 was delayed a little, but first cars seem to be about 4732901100
