BFO: Blinding (or Brilliant) Flash of the Obvious
Basically, if I can do it anyone can and like most 914 projects, it is possible to screw it up.
Background: I'm sending the door card from my 1971 to be repaired.
[/url]
First remove the two plugs at either end of the door pocket. Fingernails or a plastic spudge will do it. They are a little sticky, I guess so they are less likely to pop out.
Then, insert an Allen wrench (4mm? Mine are unlabelled!)
