Full Version: Clutch Pedel Squeak
jim_hoyland
Clutch pedel just started to squeek when I push down ? No apparent friction.. just a squeek.
Is this a signal that somethig is wearng out ? Is there a simple solution ?
any advice will be appreciated,
tat2dphreak
sounds like the plastic bushings are giving up the ghost... replace with Brass... or if you are like me, lazy, don't have the tools, and afraid of F'in it up.. I got Eric's pedal cluster!!
jim_hoyland
What is Eric's pedel cluster about ?
redshift
Pretty.. pretty cluster... about... I think it's $129... but that is probably 6, or 8 clicks from here...
Look in the member's services thingy.
M
jim_hoyland
Got a picture ?
TimT
plastic bushings are shot
Eric does a nice rebuild job with a quick turn around.. and when you get the pedal cluster back you have bronze bushings where you used to have plastic
aircooledboy
Are you sure it is coming from the pedal assembly and not the tunnel right next to it? Had the same thing, though it was the pedal, but AFTER BRAD and Andy gave me the free advice to check the source of the sound, it turned out to be my clutch tube breaking loose at the front weld. Quick spot weld, and good as new.
jim_hoyland
What's the best way to see if its' the tube breaking loose ?
