> Clutch Pedel Squeak, What's up ?
jim_hoyland
post Jun 14 2005, 06:35 PM
Get that VIN ?
Clutch pedel just started to squeek when I push down ? No apparent friction.. just a squeek.
Is this a signal that somethig is wearng out ? Is there a simple solution ?
any advice will be appreciated,
Replies(1 - 9)
tat2dphreak
post Jun 14 2005, 06:39 PM
stoya, stoya, stoya
sounds like the plastic bushings are giving up the ghost... replace with Brass... or if you are like me, lazy, don't have the tools, and afraid of F'in it up.. I got Eric's pedal cluster!!
jim_hoyland
post Jun 14 2005, 06:41 PM
Get that VIN ?
What is Eric's pedel cluster about ?
redshift
post Jun 14 2005, 06:42 PM
Bless the Hell out of you!
Bronze.. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Pretty.. pretty cluster... about... I think it's $129... but that is probably 6, or 8 clicks from here...
Look in the member's services thingy.
M
jim_hoyland
post Jun 14 2005, 06:43 PM
Get that VIN ?
Got a picture ?
TimT
post Jun 14 2005, 06:45 PM
retired
plastic bushings are shot
Eric does a nice rebuild job with a quick turn around.. and when you get the pedal cluster back you have bronze bushings where you used to have plastic
redshift
post Jun 14 2005, 06:46 PM
http://www.914world.com/bbs2/index.php?act=...=ST&f=4&t=27994
tat2dphreak
stoya, stoya, stoya
http://www.914world.com/bbs2/index.php?act=...=ST&f=4&t=27994more than a pic
aircooledboy
post Jun 14 2005, 06:47 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom"
Are you sure it is coming from the pedal assembly and not the tunnel right next to it? Had the same thing, though it was the pedal, but AFTER BRAD and Andy gave me the free advice to check the source of the sound, it turned out to be my clutch tube breaking loose at the front weld. Quick spot weld, and good as new.
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
jim_hoyland
post Jun 14 2005, 07:13 PM
Get that VIN ?
What's the best way to see if its' the tube breaking loose ?
- Lo-Fi Version Time is now: 19th September 2026 - 09:55 AM
