Wew
Aug 18 2018, 09:05 AM
Hi all,
I took 3 pictures from the center tunnel and dropping from the dash. The 4 little wires I think should have gone into a plastic housing which would plug into one of the gauges in the appearance group housing. There is also a little brown wire that is part of the harness and is short and a bigger red one that is laid on top of the harness (aftermarket)? Your input is much appreciated as I am getting close to getting this project on the road.
Thanks much,
Gary
Wew
Aug 18 2018, 09:07 AM
Another picture added as file size was to big to put in that one post
Wew
Aug 18 2018, 09:09 AM
And last but not least one more picture for clarity.
The little black hoop connection to the left next to the bulb, where the heck would that go? I do not see any place on the 3gauges that would accept the connection.
Thanks again,
Gary
Mike Bellis
Aug 18 2018, 09:33 AM
Aftermarket. Oil pressure maybe. You will have to track it down in the rear.
JeffBowlsby
Aug 18 2018, 12:05 PM
Center console gauge wiring - think about defrost light on the center console.
The long branch of the 4 wires from the dash may be for the pass side door switch if you have an early model year car.
