no problem...it's fun being part of the "community". The hose routing was "fairly" painless...I did it solo. The only tricky part was getting the hose to make the vertical 90deg transition up and out of the longitudnal...fairly tight radius. I was able to get it partially up the radius, then had to reach straight down from the front trunk and grab both hoses w/ some pliers. From there just tug, tug, tug. BTW, you have to fish the hose THEN put the fittings on.
