i have had no luck finding 4th & 5th gears. i fitted the last ne linkage bush today and i still cannot get those gears.
in the picture below it shows the gear shifter and the range of side to side movement is really narrow. i assume the slight curved notch is where 5th is? when selecting reverse should a proper working set up require the shifter to be pushed down?
how tight are the gears in the sideshift box?
i'm now at the point of opening the box up, which i would rather not do.
