Back again with a 'mini' update since there's nothing that's really 'changed' save my own level of paranoia
I've inspected the two Suspension consoles in the back, the passenger's side looks OK, but I spotted this on the driver's side which may or may not be a cause for concern (yes, at this point I'm in full OCD mode, clinically diagnosed, should not at this point come as any surprise to anyone else based on previous entries of this ongoing saga)
I mean the wrong color of suspension console, but not quite the "bwahahah, I am here to make you cry!" color
I'm not at the 'attack warning red duck and cover!' phase here, but I do think I need to find a way to wire brush the hell out of and Por-15 the area.
As I've started stripping undercoating off the area directly around the upper and lower pans in prep for drilling out the spot welds, on the passenger's side I've noticed the following oxidation that appears to be on the outer longitudinals between the floor pans and the reinforcement panels welded in by 914 Ltd (I'll be calling Brad to confirm the panels as best I can so I can tell what is a strengthening panel welded in because of the increased HP/Torque in the 3.2 motor and what is original longitudinal material)
Near the back of the passenger's upper floor pan just past the pan material
Near the lower floor pan, passenger's side
I'm a bit more concerned about these than I am the suspension console, wondering if I need to order outer rockers. I've not gotten to the driver's side yet because like an idiot, I wasted most of the marine battery power on the tar removal, and used the majority of the battery/cordless drill juice prepping the passenger's side. hence mini update status
As to interior 'tar' removal, if you have power in your garage, the heat gun is the way to go! In my case the 5000 watt A/C Inverter and battery combo meant I could once and for all remove the urethane coating from the lower floor pans area with ease. If you do not have the magic juice, dry ice works I suppose.
