pete000
Sep 9 2018, 10:40 PM
I am selling my perfect set of five factory Fuchs 2.0 wheels. These were restored by All Reed to perfection.
Five factory Fuchs 2.0 wheels fully restored by Al Reed (MINT)
Four Alloy ISP center caps
Four 5mm wheel spacers
Two Tangerine Racing Hub centric rear adapters.
Factory valve stems.
16 factory 2.0 lug bolts recently re plated with the correct silver zinc plating.
Wheels all date stamped 4/73,11/73,12/73,12/73,12/73
Will sell all for $1800.00 plus shipping.
This is the perfect setup for the narrow body 914.
Note: That is copper anti seize on the lugs...
914_7T3
Sep 9 2018, 10:54 PM
What are the date codes and are they all the same?
pete000
Sep 9 2018, 11:59 PM
I will verify the date codes shortly...
Sep 10 2018, 05:22 AM
Great price. Cost that much do get it done now.
amfab
Sep 10 2018, 11:56 AM
OT but, man that car looks clean. Door gaps look perfect
pete000
Sep 10 2018, 11:39 PM
I would rate these wheels a 9.98 out of 10
orthobiz
Sep 12 2018, 09:55 AM
Lug bolts??
Paul
orthobiz
Sep 12 2018, 09:56 AM
QUOTE(orthobiz @ Sep 12 2018, 11:55 AM)
Lug bolts??
And is that Saturn Yellow?
Paul
designerguy90
Sep 12 2018, 11:34 AM
PM Sent
914_teener
Sep 12 2018, 02:14 PM
I'll be second in line Pete if it falls through.
Rob
pete000
Sep 12 2018, 02:40 PM
Going in order of responses, if first passes this weekend goes to second, etc...Thanks for the kind comments, this car is a gem.
914_7T3
Sep 12 2018, 02:56 PM
QUOTE(pete000 @ Sep 12 2018, 01:40 PM)
Pete,
Not sure if you were considering me in the order of interested parties, but I'll speed up the process by taking a pass. I decided to restore my original set that is date coded to the same month as the production of the car.
Nice car BTW and hope to see you on Sunday
pete000
Oct 3 2018, 06:06 PM
Update on the wheels, they are good to go with all tires now dismounted. I am now including the following.
pete000
Oct 5 2018, 07:51 PM
SOLD,Thanks!
AMac
Oct 16 2018, 07:17 PM
QUOTE(pete000 @ Sep 9 2018, 09:40 PM)
Hi, Im looking for wheel spacers, where did you find the 5mm 4 bolt? I agree 5mm makes most sense. My wheels, 2.0 such, are refinished ready to go back on. Thanks Cheers, Andrew
Oct 16 2018, 07:32 PM
QUOTE(AMac @ Oct 16 2018, 09:17 PM)
amazon has them
https://www.amazon.com/4x100-Hubcentric-57-...t+wheel+spacers
pete000
Oct 16 2018, 11:00 PM
To be honest I can't remember where i got them, but they seem to be readily available. 5mm is the max you can run on the 2.0 wheel bolts.
jos.hall
Oct 17 2018, 01:10 AM
make sure you order the 4x130 and not the 4x100 in the Amazon link.
