QUOTE(dr914@autoatlanta.com @ Sep 14 2018, 08:00 AM)
I agree as well, certainly a rigged up system on the 914 back then./
We do sell the modern systems with r134 and radial compressor. Install a bit better but still the front trunk rear compressor long ac lines under the rocker panel
Beats however the 916, that has the compressor on the left behind the driver with the firewall cut and a fiberglass hump to let the compressor clear. THEN the ac lines were run down the center of the bottom of the floor pan with a ragged cover over them!!!! And BRUMOS did this!!!!!!
Thanx George H!
I asked because the last time I looked for them on the AA site to refere someone to you/them, the old link was a dead end, & nothing came up on a website search with your new website.
Please post links for them, so I can re-bookmark them. As I recall you had 2 versions, with either 1 or 2 condensors as the 2 options.
Thanx!
Tom
