QUOTE(Josh K. @ Nov 25 2018, 11:06 PM)
Thanks everyone! It's been a busy last few months and I'm now back in the garage!
I've got to strip the silver car and scrap it so I'm formulating a plan for the black car. So far I'm going to pull the interior out of the silver car and swap into the black. I'll use both front fenders and rear quarters as someone used 4 to 5 lug adapters on the car and did a really bad job pulling the fenders to fit the tires. It's a mess. I'll probably swap the panels and weld on steel flares later.
First things first! I'm going to swap the sideshift tranny and need to resolve the water pump issue. Currently the tail shift setup prevents the water pump belt from going on. The motor is slanted nose down and there's washers under the engine crossmember. Taking out the washers won't resolve and if I go any higher the valve cover will hit the firewall. Seems the best choice is raise the motor up, drop the rear and push everything back.
Can someone tell me what's going on here? Should the shift rod run through the center of the belt? I can't find any pictures online.
My 2cents
For many of the people in this 'world' the silver car looks pretty interesting. The lower 1-2 inches of all 914s rust. You can hear 'em rust'n when you roll them out of the showroom (at least in our salt infused roads here in north country).
As a result it is fairly straight forward to replace the rusted parts. every part that rusts is available for pretty fair prices.
In short, my personnel preference would be to put back together a Porsche design rather than a collection of 3rd party ideas.
Either way, both were a great find, good luck with the project(s).
CTC911CTC
