shelby/914
Oct 1 2018, 05:58 PM
I've decided not convert. Already sold the 5 lug wheels, so the rest sould go too. Struts, hubs, rotors $300 plus shipping. Parts are in the Denver Colorado metro area. Not too bulky, but a little heavy. Some surface rust on one side of the rotors from sitting in my barn. Will send more pix if you are interested or have someone local look at them.
Reducing price to $275. Also 3" spacing. Had them sold twice but buyer wanted to use Boxster calipers which have 3 1/2" spacing.
Dan
shelby/914
Oct 1 2018, 06:00 PM
9144me2enjoy
Oct 1 2018, 06:04 PM
Pm sent....go ahead and pass to BPAC. Thanks
BPic
Oct 1 2018, 06:20 PM
Can I be next in line if 9144me2enjoy doesn't take it? PM Sent.
bdstone914
Oct 1 2018, 08:55 PM
QUOTE(shelby/914 @ Oct 1 2018, 04:58 PM)
I've decided not convert. Already sold the 5 lug wheels, so the rest sould go too. Struts, hubs, rotors $300 plus shipping. Parts are in the Denver Colorado metro area. Not too bulky, but a little heavy. A little minor surface rust from sitting in my barn. Will send more pix if you are interested or have someone local look at them.
Dan
Click to view attachmentAre those pinch bolt type struts or taper pin struts?
If pinch bolt they will fit the early 1970 to mid 1972 914 struts. Either way the buyer will need to use the ball joint that fit that strut.
shelby/914
Oct 1 2018, 11:03 PM
Not really sure if it requires bolts or pins. Can you tell me what to look for as I have several peple who have expressed interest. I purchased these about 10 years ago from Eric Shea at PMB and it was never mentioned. I know I told him that I was going to use a set of cookie cutters, but not sure I told him I had a '76.
Dan
bdstone914
Oct 2 2018, 07:37 AM
@shelby /914
Not really sure if it requires bolts or pins. Can you tell me what to look for.
Look fo a split in the bottom of the strut where the ball joint installs. That indicates pinch bolt type. Here is one with damaged ball joint holes.
On a late car you would need to switch to the early more expensive ball joints.
Bruce
bdstone914
Oct 2 2018, 08:04 AM
A tip on shipping. Go to Lowes or home depot and get a 27 gallon storage box for under 10 dollars.
Unless the rotors have no ridge they may not be the cost of shipping.
Oct 2 2018, 08:19 AM
QUOTE(bdstone914 @ Oct 2 2018, 10:04 AM)
A tip on shipping. Go to Lows or home depot and get a 27 gallon storage box for under 10 dollars.
But the struts and hubs will even fit into the slightly smaller tub. 22 gallons I think. Line the box with cardboard and zip tie shut. I don’t usually ship rotors with the parts since they are so heavy and usually worn out.
rhodyguy
Oct 2 2018, 09:31 AM
I used a Rubbermaid tote for these items. iirc 24x15x12. It will all fit with room to spare. I put not so tall pieces of plywood along the bottom of the sides to keep the struts from punching thru. Bubble wrap (@YouHaul) came in handy. I Drilled holes in the top and edges so I could use LOTS zip ties to secure the top. Shipping, 56lbs, from a distribution center ran $37 from Tacoma to NorCal with my FedEx account.
Hard plastic totes are the wrong choice. Great for storage but crappy for shipping. Too fragile.
shelby/914
Oct 2 2018, 11:21 AM
Thanks for all of the info on the parts and shipping. Really helpful and much appreciated. There is a split on the bottom so definately pinch bolts.
bdstone914
Oct 2 2018, 12:10 PM
QUOTE(mepstein @ Oct 2 2018, 07:19 AM)
I have shipped many times with these plastic totes. The quality of them varies. I drop them on the floor before buying them from waste height. Sometime the corners are thin.
Literati914
Oct 2 2018, 12:50 PM
so just to be clear, any of the 911 struts will work on any of the 914s... the ball joint to be used is the issue - correct ?
..and the stock ball joints used on 914s to mid '72 work with a "pinch bolt" type strut - and those earlier ball joints are more expensive than the later used taper pin ball joint. but one can be switched out for the other - depending which 911 struts you source. Do I have that summed up correctly?
Oct 2 2018, 01:20 PM
so just to be clear, any of the 911 struts will work on any of the 914s... the ball joint to be used is the issue - correct ? ---Yes, as long as you use the correct sized ball joint, calipers, rotors and strut inserts.
pinch bolt style struts take pinch bolt style ball joints, taper pin struts take taper pin ball joints. You can use your existing A arms for either version The cost of the early ball joints may be a bit higher but it's not much by the time you go 5 lug.
front conversion:
struts
strut inserts
hubs
bearings
hub seals
calipers
rotors
hard lines
soft lines
hardware
wheels
some guys use one inch spacers on the front to fill out the wheel wells on flaired cars when using 7' wheels so include the spacers and longer studs.
dgale914
Oct 3 2018, 03:05 AM
I have a bunch of 15" and 16" Fuch wheels here in the Sacramento area if the person buying these parts needs wheels. Some are reproduction and some are originals. Need to clear out some space in my shop.
PM me if you need wheels.
Doug
shelby/914
Oct 9 2018, 02:41 PM
Bump for the price reduction
Chi-town
Oct 9 2018, 04:24 PM
I'll take this, PM me payment info
sholman5
Oct 9 2018, 05:46 PM
Hell of a deal. Great buy and price.
