Full Version: Anyone Try These Repro Back Pad Lights
Mike Fitton
These look pretty good except no VW or Hella logo. Has the chrome trim has anyone tried them?
https://www.bughaus.com/dome_light_assembly_-_111947111D.htm
dr914@autoatlanta.com
certainly would be a lot more correct looking, at a price of course!
QUOTE(Mike Fitton @ Nov 29 2018, 09:21 AM) *
DickSteinkamp
The problem I've found with ones like these is the indentations on the ends that "click" into the metal tabs in the back pad are too shallow. They are made for a direct click into sheet metal like a bug roof panel. Ours need to be deeper into the housing (closer to the surface of the light) to account for the thickness of the vinyl, padding, particle board AND the metal tabs the fixture ultimately clicks into.
Who makes a repro that works?
burton73
https://sierramadrecollection.com/914-914-6...-76-p19837.html
Sierra Madre
Price:
$12.66
Part Number: 111.947.111D
Type: Aftermarket
Model: 914, 914/6
Year: 1970-1976. Button is Black not white
I bought a couple of these. No silver on edge but you could paint it on back
Bob B
Chris914n6
914rubber
yup we have plenty of these, 9.50 each but not correct. Have to file a notch deeper in the side to have it click in
So many of these are made now all different, we investigated making a perfect copy but very expensive to do and the market is saturated with cheap retros that just do not work correctly.
Even the one from Porsche does not work properly NOR work correctly
QUOTE(burton73 @ Nov 29 2018, 10:00 AM) *
Sierra Madre
Price:
$12.66
Type: Aftermarket
Model: 914, 914/6
Bob B
Tom_T
Mike & All - all 3 mentioned so far aren't really correct look either - aside from fit.
That one has the wrong size & shape white button more of the early 1960's Beetle/etc. era look, & I'm not sure that the clips will actually work to attach it.
IPB Image
PS - VW Heritage calls it 1954 - 69 Beetle application:
https://www.vwheritage.com/111947111c-inter...e-edge-vw-spare
They carry the later "E" version with black button (out of stock right now), & the chrome version ends in "D" FYI -
https://www.vwheritage.com/111947111e-inter...-light-vw-spare
SMC's doesn't appear to have the "chrome" painted rim.
The 914Rubber one is a black button by EMPI.
AFAIK they still sell the Hella (Mexico) black button ones which do fit well as the 914 replacement/superseded part (i.e.: as used on the 74-76 MY 914s), which is what I'd use over all of these.
IIRC there was a correct or close-to-correct white button with "crhome" paint rim one sold by "Oldtimer", "Newtimer" or some seller name like that on German evil-bay, which may be worth checking out (they also sell the repro 914 visor + pins/brackets sets).
PS - IIRC this is the one noted above -
https://oldtimer-ersatzteile24.de/Innenraum...uer-Porsche-914
DickSteinkamp
QUOTE(Tom_T @ Nov 29 2018, 10:16 AM) *
Thanks...who sells those?
914_teener
Unless you want a stock look, I'd suggest and LED replacement light.
Doesn't run as hot and produces real light instead of the stock candleflicker ouput.
bbrock
QUOTE(DickSteinkamp @ Nov 29 2018, 02:47 PM) *
Tom, is it this one? https://www2.cip1.com/ProductDetails.asp?Pr...11-947-111-HELL
DickSteinkamp
QUOTE(bbrock @ Nov 29 2018, 02:10 PM) *
If it fits a beetle, it's not going to work on a 914 without modifying it.
914Sixer
German Hella still available. Black switch and no chrome lip. $25 on ebay under VW Rabbit MK1
Ebay item 171969778782
porschetub
QUOTE(914Sixer @ Nov 30 2018, 01:59 PM) *
German Hella still available. Black switch and no chrome lip. $25 om ebay under VW Rabbit MK1
Ha Ha,knew you would find something,king of NOS on here is Mark...no dispute smilie_pokal.gif .
I'am forever amazed @ the crossover within the VW group,lots of parts moving around to other models ,I think we will soon get the the stage we can't buy these anymore confused24.gif confused24.gif .
I guess if you have a good one put an LED in it and save it from certain crumpling of the clear plastic sad.gif sad.gif .
rgalla9146
QUOTE(914Sixer @ Nov 29 2018, 07:59 PM) *
The best choice after a flat white switch/chrome edge original.
