As I found out, SBC old school V-8's are a different breed. The na Subaru is a much more efficient engine and doesn't produce or hold much heat. I never had a cooling problem when I had the small coolant lines run through the longs. Nor did get any heat in the cabin from having run those lines through the longs. The only reason that I changed to the under carriage route and larger hose is ignorance on my part. I was chasing my own tail at the time. When you run the lines down, up and back down they can trap some air but look and you'll see hose clamps that can be loosened to bleed the air at the high points. Quick and easy to bleed.
