Tdskip
Apr 7 2019, 11:57 AM
Gentlemen, hope everybody’s having a good weekend. I’m going to be doing crank bearings in piston rings on my Triumph TR6 soon, and that is in the engine in car thing. A bit messy, but not terribly complicated.
I don’t think there is the equivalent bearing and piston ring refresh without taking the whole engine apart on our Type 4 engines however, correct?
I always have a ton to learn about these engines still, I’ve never opened one up so forgive me if this is, even by my standards, a brain-dead question.
Thanks!
Apr 7 2019, 12:29 PM
You can do just a top end refresh on a type 4 or six. It's common on a six to have to replace broken studs so heads are usually done at the same time. A 3.2 has Dilvar studs and soft valve guides but might run the bottom end for 200K.
Mark Henry
Apr 7 2019, 12:49 PM
Type 1 & 4, 356 case has to come apart for bearings, cam and crank, /6 apart for crank. IMS, bearings and pump.
Rods and bearings can be done without splitting the case, Type 1 & 4 if you're that far I'd split the case.
thelogo
Apr 7 2019, 04:37 PM
This stuff must require one expensive torque
Wrench
But if you build it
It will hum
Tdskip
Apr 7 2019, 05:32 PM
Thanks guys
