I started cleaning an inspecting the harness for a August 1972 car. I found one main issue of melted wires, that I will replace.
Does anyone know where I can get the correct color and size wire to replace this? Looks like I'll need about 30 feet as both wires are melted from beginning to end. Luckily it didn't melt any others in the harness.
This next one is in the wiper motor portion of the harness. I started removing the casing from the connectors and worked my way up and found this wire terminated as you see it. so it comes from the main harness and did a loop as pictured but wasn't connected to anything just taped into the bundle. Is this normal?
The 3rd issue I found was coming from the fresh air box connection one of the red wires was cut and there is no other red wire in the harness that it would have been connected to. Again, is this normal?
Fourth issue is the 14 pin connector. Where can I get one?
Thanks everyone. Any assistance is greatly appreciated!
