QUOTE(Optimusglen @ Apr 15 2019, 07:53 AM)
A laser scan typically generates a point cloud, good enough for a polygonal model but not an engineering level nurbs model that you'd need. The point cloud or polygon model can be used as a "seed" to create the nurbs model. Which can then be manipulated to create the DXF cross sections to make the buck.
My main concern is about the source though, a 1/24 scale model may look very good at it's scale, but I think only the broad surfaces would transfer well to a full size vehicle. Maybe that's what you're going for.
The other thing that concerns me if if you're planning on incorporating these panels with an actual car. i.e. if I were to scan a door off of a 1/24 scale model, the chances of it being proportioned correctly to be used on the life size version are slim to none.
At any rate, to the heart of your question. I've looked into renting scanners and it can be done fairly economically for small scale stuff like that. I can't help with that portion but if you need someone to do the 3D model work I may be able to (depending of course on timeframe)
@Optimusglen - I was hoping you'd chime in! LOVE your work, btw.
Re:this project: It's a race car body, no doors or roof. My customer is aware of the possible scaling issues and initial review of the model has us thinking some modifications may be needed - and that's OK.
I'll PM you and perhaps we can talk over some details.
Thanks!
Chris
