QUOTE(maf914 @ Apr 23 2019, 09:28 AM)
Steve,
Do you have a front mounted oil cooler under that duct? I was wondering where the cooling air for the AC condenser comes from. Is there additional ducting that is not obvious in the photo?
Yes there is a PMS oil cooler under the shroud. I shortened the shroud so the air exits underneath in front of the condenser. For the condenser, the air enters through the front holes on each side of the shroud. I use the tire board on top of the shroud to force the air through the condenser. The oil cooler has fans and a thermostat. The condenser also has its own fan. I have not plumbed the AC yet, so we will see how well it works... I have a Benling DC Compressor and small evaporator for the console.
