echocanyons
Jun 25 2005, 01:07 PM
I need the factory specs on the fore/aft movement limits for the crankshaft.
What impacts this movement?
Cap'n Krusty
Jun 25 2005, 01:22 PM
.07-.13mm (003-005"). Set with shims under the flywheel. The details of this are in most applicable manuals. The Cap'n
echocanyons
Jun 25 2005, 01:30 PM
Thanks, I guess I shoulda consulted the haynes first
ArtechnikA
Jun 25 2005, 01:38 PM
crankshaft end play in The Spec Book is 0,07-0,13mm with a 0,15mm wear limit.
the clearance impacts the #1 main bearing :-) ...
it's set with exactly 3 shims between the crankshaft and the flywheel.
that's from a combination of my memory and the Spec Book. it's in the Haynes, but mine is missing at the moment.
if someone posts more accurate or definitive data, i'll gladly delete this post ...
