Good morning and happy fathers day. I recently thought it was a good move to install a new turn signal switch for my 914 as the left turn signal had been acting up. I purchased the copy part that Sierra Madre sells. The quality looked good but the pieces that came on the "new" part that the guide the wires through the column were too big to fit so I retrofitted the parts from the old one I removed.
Anyway all items work fine including the signal and all other stalk features. Issue is now that the horn honks all the time when turning the wheel. I can no longer get the button to ground and have the horn honk.
I have a momo wheel hub and an OEM Porsche horn button. Any recommendations on where to look or make adjustments? I already adjusted out the piece that is attached to the turn signal switch to see if that would help but it doesn't.
Please help or let me know where I can buy a good OEM turn signal stalk as I expect that to be the problem.
Thanks in advance,
Casey
