QUOTE(Mblizzard @ Aug 8 2019, 01:36 AM)
Attached is a template that lists the timing marks.
Click to view attachmentAttached below is a 2.0 impeller.
Click to view attachmentIt is possible to put the dizzy in 180 degrees out
The way to verify if you are on TDC of the firing stroke of the #1 cylinder - pop the valve cover off the #1 side and both rockers should be loose. If not, spin the engine 360 and check again.
Click to view attachmentThe fan I'am using is a bus one as its all I have with my current build,they or most have the "0" marked and nothing else,Haynes manual states measuring 52.5mm and you get 27 degrees but that is for a FI motor,I will most likely mark to get 30 degrees as running carbs.
Cheers for that info Mike.
